Slabs and walls automatically trim each other based on the Intersection Priority strengths of the Building Materials.
The problem you are having is that the strength for the BM of the slab is stronger than the BM for the outer skin but weaker than the BM for the inner skin.
So the wall is cutting the slab away automatically at the inner skin - so there is no slab left to do your SEO with upward extrusion.
You need to make the slab BM stronger than the wall inner skin BM (be careful as this may affect other connections) or change the slab BM for one that is already stronger.
