Spiral stair tread depth at walking line?
Mats_Knutsson
I want a specific walking line length of the tread measuer at the outer diameter of the tread. I have moved the walking line but still the length (300mm in my case) is measured at center (where the walking line from the beginning). How do I do this correctly?
/Matsstair issue.png
AC 25 SWE Full
For the winder settings you have to change from "fixed - centre"
You can then set the offset you want the walking line to be measured at.
You may also have to turn off the rule about the walking line offset range.
Mats_Knutsson
❤️ you Barry. I've done this a couple of years ago and totally forgot this. The trycky thing here is that I moved the walking line in the Edit > symbol mode... but It is obviously just a graphic representation...has nothing to do with the walking line used for the calculations...as I get it. So ...super easy to do this as long as I don't tweak the symbol walking line (must admit I was impressed that it was so easy to just move it in the symbol mode...fake thing really).
AC 25 SWE Full
