Stair 3D Textures
Ghassan Kanaan
Hello everyone , Archicad doesn't seem to offer a way to redefine the 3D texture Origin for the Stair as for the Slabs with  ("Set Origin").
The result is that the texture maps cannot be aligned inside the stair itself and between the stair and other components.
I am waiting for your comments please...Screenshot (29)_LI.jpgScreenshot (30)_LI.jpgScreenshot (31)_LI.jpg
Sadly you can't have hotspots in a stair component, as it looks like. 😞
So that idea of mine has to be scrapped; you would need to rely on manual input.
It's possible to edit the "basicStairTread_m" macro and its texture fitting method (right at the bottom of the 3d script).
Might not be worth the effort, tho.
runxel
Legend
The components of a stair are actually GDL elements. The "set origin" command is not available for any GDL object since the surface and its mapping is controlled by GDL code.
So what could be a workaround? Probably the treads (and risers) would need to be scripted to allow for a change of mapping origin. I'd look into this.
Thank you for your contribution.
