Stair Maker
GFBArchitect
I hate the thing in stairmaker that keeps trying to make the ratio of rise to run fall in a certain ratio and then give error messages. Since that ratio is no longer in the code it isn't needed. Can this be eliminated or bypassed?
Thank you!
Gayle Berkey, Architect
Littleton, CO
AC-20 USA, ACPI x64 PC, Win10 Pro, i9-9900K CPU @ 3.60GHz 3.60 GHz 32Gb ram
In such a case I would just set the minimum and maximum values for the (2*Riser)+Tread fields to low enough and high enough values so even if those values change they do not give an error message.
As I see, 200 is the minimum you can set, but there is no practical upper maximum.
GFBArchitect
Thanks, You're right, I was just too impatient and didn't notice the variable settings.
Littleton, CO
