Stair numbering hidden by a balustrade
As shown on this image, our associative balustrade on the stair covers up the tread numbering in plan. Might be missing something obvious here as I can't find it elsewhere on this forum. Is there a way to offset the numbering in MVO or the stair settings?
Thanks for any help,
The MVO will only have an option to show or hide the numbering.
Delve into the stair settings and you should see a section for the numbering.
In there you should find an offset parameter.
It maybe a 'Relative position on tread' expressed as a %.
You can also go into 'EDIT' mode for the stair.
Select 'Symbol' in the dialogue box and so long as you are not using the 'Built-in' numbering you should see a moveable hotspot for the numbering when you select it.
The built-in numbering does not seem to have a moveable hotspot
This is the field Barry is referring to.
