The MVO will only have an option to show or hide the numbering.
Delve into the stair settings and you should see a section for the numbering.
In there you should find an offset parameter.
It maybe a 'Relative position on tread' expressed as a %.
You can also go into 'EDIT' mode for the stair.
Select 'Symbol' in the dialogue box and so long as you are not using the 'Built-in' numbering you should see a moveable hotspot for the numbering when you select it.
The built-in numbering does not seem to have a moveable hotspot
