That should work for the tread and structure surfaces, but rail is part of the saved stairmaker object, I believe.
Not entirely sure, because I hardly ever use the handrails from stairmaker.
If there are settings you use over and over again, I believe you can also edit the original stairmaker .gsm loaded in library.
I generally get a stair from a previous object and use the syringe method described above to get all the parameters the way I like them on new stairs.
www.leloup.nlArchiCAD 9-24 NED FULL
Windows 10 Pro
Adobe Design Premium CS5
