Stairs visualization on plan
stevini
Hello folks,
I draw stairs heading to the entrance of the ground floor. They are therefore below the ground floor and 1.7m above the basement.
The floor plan cut plane is set to be at 1.1m from the floor level.
The question is: why Archicad continues showing the stairs at the basement plan even though they are above the floor plan cut plane? I need them not to be shown at basement level.
You can set so that it only show on one story up from it's home story.
Stair Selection Settings > Floor Plan Display > Floor Plan Display Layouts and choose Show on: One Story Up in the dropdown menu.
Thank you very much! It worked perfectly!
