Design forum
Stairs with 3 flights
nejcek74
Somehow I am not able to make stairs with 3 flights going inside same geometry.
Yes, I know I can divide them in 2 or 3 stars, but that's a "caveman's" solution, it doesn't allow changing or adaptions.
So, am I missing something or the stair tool is simply too limiting?
I want to get stairs like one on left (they are drawn with second stairs and manual landing) but the tool doesn't allow me to turn the 3rd top flight back.
Archicad 22 on OS X 10.11.6
6 REPLIES 6
Erwin Edel
Most likely the stair can't cross over itself. It looks like you'll have to go back to that cave to solve this.
www.leloup.nl
ArchiCAD 9-24 NED FULL
Windows 10 Pro
Adobe Design Premium CS5
Exactly.
You can have as many flights in a single stair as you want, but the upper portion of the stair can never cross over the lower.
Versions 6.5 to 25
Dell Precision 3510 - i7 6820HQ @ 2.70GHz, 16GB RAM, AMD FirePro W5130M, Windows 10
nejcek74
Thanks both of you. So, it is as usual, so many options, just not any useful.
Why can't the stair cross over itself? Is that a programming issue?
Odette Salem
www.virtualhouse.com.au
AC22 AUS . Intel(R) Core(TM) i7-7800X CPU @ 3.50GHz . 32.0 GB ram . 64-bit operating system, x64-based processor
I believe so.
Versions 6.5 to 25
t6nis
Hey. Is there a feature request we can vote for? I can't find it so far. I see those stairs with three goings everywhere in my work and real life. When a building has many floors, it is cumbersome to go into a cave for something so elementary. Instead of all those revit-killer plumbing solutions, a simple step to make an already existing Archicad-architect's life easier ...
Didn't find the answer? Start a new discussion
