Standard command box disappeared?
Hi, this is probably a very basic question.
I am using archicad 13, and when i click and hold on an element the standard command box is not showing up (the one with drag, rotate, mirror, multiply etc)
This has never happened before. How do I fix it? Thanks
2 REPLIES 2
I can't recall having seen this. Perhaps there is a setting in the Work Environment. I know there is (or was) a setting for the palette to move to a default location or follow the cursor (the pest palette setting). Perhaps changing (or toggling)this would help.
Erika Epstein
Try doing a new and reset.
While opening a new file, File>New hold the alt/opt key down and it will say New and Reset. This won't hurt any open files, although I'd close them. This will restore the default settings.
HTH
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Learn and get certified!
