Installation & update
Start error :(
I installed and setup Archicad13 Education version. But I can't open it. It gives an error every opening. I have Quicktime 7.6.8. and I use Windows 7. What can I do?
Problem: QuickTime is either outdated,
not properly installed or missing.
ArchiCAD 64 bit version requires QuickTime 7.5.5 or later,
image compressors, decompressors, and required GSQtCom.
Make sure you have QuickTime installed with the "Recommended"
option chosen at installation, instead of the minimal option.
Uninstall QuickTime, then reinstall it using the "Recommended" option.
You must also run the GSQTcom.exe to register it.
0 REPLIES 0
