2017-12-29 06:33 AM
2017-12-29 06:57 AM
2017-12-29 08:06 AM
2017-12-30 06:25 AM
Karl wrote:Use the Open Object by Subtype... command, then navigate to General GDL Object > Documentation Element > Drawing Symbol > Marker > Story Marker > Built-in Story Marker. It looks like the standard marker is close: set the Text Settings > Alignment to Outside, then if the parameter Marker > Story Name Placeholder could be a negative number (it is currently restricted to => 0), then the text could be inside the marker.
I tried to open the story maker object thinking I might edit it, but I don't see where it is available in the ArchiCAD 21 Library.
2018-01-02 05:20 AM
David wrote:Thank you - I'll give it a try.Karl wrote:Use the Open Object by Subtype... command, then navigate to General GDL Object > Documentation Element > Drawing Symbol > Marker > Story Marker > Built-in Story Marker. It looks like the standard marker is close: set the Text Settings > Alignment to Outside, then if the parameter Marker > Story Name Placeholder could be a negative number (it is currently restricted to => 0), then the text could be inside the marker.
2018-01-02 12:58 PM
2018-01-03 06:22 AM
2018-01-08 12:00 AM
2018-01-08 09:46 PM
