SOLVED!
Stretchy 2D symbol made from fragments?
Paul King
It has been too long since I have had a chance to do much with GDL, so hoping someone has a quick and easy solution.
I have a bunch of 2D objects based on drawn fragments that can be parametrically switched off and on.
I would like to be able to stretch these when placed by dragging corner hotspots, but no combination of settings in object editing dialog seems to allow this.
I seem to recall it being possible at one time. In face I recall this tendency being an actual problem in some cases.
I have been playing with compatibility options in particular (saving object and reloading libraries each time), but none of these options has any noticeable affect on stretchability, though I could have sworn they once did.
What am I missing?
More importantly, how can I otherwise rapidly rescale a placed dumb 2D object independently in an x or y direction (accepting the distortion of curved elements etc) - without resorting to elaborate scripting to generate each line in the symbol ?
PAUL KING | https://www.prime.net.nz
ArchiCAD 8-27 | Twinmotion 2023
Windoze 11 PC | Intel Core i9 10900K | Nvidia Gforce RTX 3080 | 32 Gb DDR3 | 2x4K monitor extended desktop
1 ACCEPTED SOLUTION
Solution
The compatibility options you show have nothing to do with what you want.
The store ration button you have selected just means if you change the A or B value in the object script and re-save the object, it will affect all placed instances of that object.
The other one for 'Store Fixed Values' is the better option.
What you want is a simple MUL2 command before the FRAGMENT command.
So let's assume you have a default A value of 1000mm and a default B value of 1000mm in your object.
MUL2 A/1.000, B/1.000
FRAGMENT2 1,0
DEL 1
This should now stretch as you adjust the A and B values in the place object instance.
You could also add adjustable hotspots to make the stretchy graphical.
2 REPLIES 2
Solution
FRAGMENT2 1,0
DEL 1
Paul King
Awesome, thanks Barry
My 10 years younger self kicks present day me in the shins for forgetting about that stuff!
Learn and get certified!
