Stupid Question re. Zones
Dave Jochum
I've not used zones before, but I have ranted about the pathetic AC manuals which are useless to me and my feeble mind for this. I used the auto recognition method to define the area. The label I defined shows on the plan. In the Zone Selection Settings no area calculations are shown. The Zone Stamp area of the dialogue box states "Not avail. in loaded libraries". I have the AC 8 library loaded. What the *bleep* am I missing??
Dave Jochum
J o c h u m A R C H I T E C T S http://www.jochumarchitects.com
MBP 16" (M1 Max) 64 GB•OS 13.5.2•AC 27 Silicon (latest build)
14 REPLIES 14
Dave Jochum
Here's the plan view. Actually, I've found that if I choose any of my other categories, the label will show the zone name. Is there some special override with GROSS AREA?
Dave Jochum
Dave Jochum
OK, sorry. The screen capture creates a pdf. I have to convert to jpeg in Photoshop and can resize then. Am I missing a quicker, more direct method? (Why is your original quote not showing here? I highlighted it before replying. Guess I'd better read up a bit on using this forum.)
Dave Jochum
Click "quote" in the top right corner of the other person's message. A reply form will open and their message will be quoted in it.
HTH
Kim
KenMcN
Dave wrote:
OK, sorry. The screen capture creates a pdf. I have to convert to jpeg in Photoshop and can resize then. Am I missing a quicker, more direct method?...
You can also open the pdf in Preview and export it as jpg. I use a contextual menu called QuickImage (freeware, from VersionTracker, AFAIK) which gives you a pop-up that converts formats and size of image etc. very quickly & easily (I'm using 10.2.8 at the moment, not sure about 10.3).
But back to the subject - sorry, I can't really think of any other simple solutions, not such a "Stupid Question" after all Perhaps it's due to the definition of the Zone Category Geoffroy mentioned a few posts ago?
Good luck. Kenny.
7.0 V3, Mac OS X.2.8, G3/400 Pbook, 320Mb RAM
V25 & 26 (fully patched); Mac Ventura, MacBook Pro M1 Max
Yes - I seem to remember having that problem earlier this year. Gross area doesn't do room names, because it's assumed to contain overall zones, not specific ones.
That's what I concluded, anyway
