Surface Problem. On shell, surface not working, it's ratio deforming.
aryastark
i want this image pattern should cover the surface without change it's ratio.
couldn't find where is the problem.
Ver: AC23
Operating System: Windows 10 64-bit
Processor: Intel(R) Core(TM) i7-6700HQ CPU @ 2.60GHz (8 CPUs), ~2.6GHz
Memory: 16384MB RAM
Card name: Intel(R) HD Graphics 530
Chip type: GeForce GTX 960M
aryastark
i found a solution:
converting it to morph object. is working.
Ver: AC23
Memory: 16384MB RAM
1 REPLY 1
aryastark
i found a solution:
Ver: AC23
Memory: 16384MB RAM
