Switching views keeps layer settings of previous view
onestoreyllc
It seems like after the last AC26 update this has been happening but when I switch between views, say from plan to section, the section, though saved with it's own layer settings is created with the floor plan layer.  This makes switching between views incredibly frustrating because I always have to reselect the view when switching between tabs to get the proper layer settings to load.
It's hurting productivity, is anyone else having this problem?
Meredith
AC26 USA - Lenovo P17 - Intel(R) Core(TM) i9-10885H CPU @ 2.4GHz - 32.0GB - Windows 11 Pro
12 REPLIES 12
gdford
yes I am - it is a pain - It happens to me in V25 (current patches)
Gary Ford
Self Employed - Modeling, Estimating, Construction
Archicad 12-26
AMD Ryzen 9 5900X 12-Core Processor
3701 Mhz, 12 Core(s), 24 Logical Processor(s)
(RAM) 128 GB
NVIDIA RTX A2000
DGSketcher
Legend
This used to happen in the Navigator list, I guess it must still be present between Tab views. I have noticed recently that it can be consistently generated by switching from Schedules to a drawing using tabs in V26 4019. I haven't had the time to report it, so hopefully someone from GS will pick up on this thread.
Yes, I also have it happen in the navigator list.
Meredith
Rubia Torres
Hi @onestoreyllc@gdford and @DGSketcher,
We kindly ask you to report this issue with a step-by-step of reproduction and affected Archicad version and build to your local Graphisoft distributor for further investigation. You can find their contact information here: Get in Touch – Graphisoft.
Regards,
Rubia Torres
Community Specialist | GRAPHISOFT SE
Need help refining your Archicad skills?
Check our Modeling knowledge base for the best workflow + tips&tricks!
Botonis
Are you double clicking when changing tabs?
Botonis Botonakis
Civil Engineer, Enviromental Design MSc., BIM Manager for BS ArhitectsVR
Company or personal website
Archicad 27. Windows 11. Intel Xeon 2699x2,64 GB RAM, Nvidia 3080Ti. 2 Monitors.
yes.   it's very odd, the walls were connecting properly and then they weren't.
Meredith
Also I find in V25 that the view settings display at the bottom of the view list is reliably does not list the settings correctly for the view I am clicking on.
Gary Ford
Archicad 12-26
(RAM) 128 GB
NVIDIA RTX A2000
Nicholas Jones
Has this been resolved? this is happening on 26 for me and working in schedules it is quite frustrating.
AC25 solo UK • 2017 MacBook Pro 15" 2.9GHz Quad-core i7 16 gb ram
OSX10.15.5
Rubia Torres
Hi all,
This is a known bug, registered in our system under DEF-4194 - the view opens with the latest used layer combination instead of the saved one. If you encounter this issue, we kindly ask you to report it to your local support to raise its priority in our backlog.
Meanwhile, we would recommend as workaround to set the desired layer combination in the source viewpoint (project map) and then open the respective view. We apologise for the inconvenience that this issue may have caused you.
Best,
Rubia Torres
