Taking plans, sections or any 2D drawing into photoshop
Hello, I am doing my final year project to ArchiCAD and I am fairly new to this software. I want to know if it is possible to move plans, section, elevations or any 2d drawing into Photoshop will retaining the scale set in Archicad or Layout Drawings. I have tried a few methods but the image quality is bad (blurry lines ) and not to scale. Help any suggestion well be helpful.
runxel
Legend
Hey Isa!
Please tell a little bit more 🙂
Where do you want to layout the final plans?
Lucas Becker | AC 27 on Mac | Author of Runxel's Archicad Wiki | Editor at SelfGDL | Developer of the GDL plugin for Sublime Text |
«Furthermore, I consider that Carth... yearly releases must be destroyed»
Topic has been moved.
Isa,
Export plans etc from a layout tab as PDF. In photoshop open the PDF file you just created you should be prompted for the size and resolution which you want photoshop to render the file to
Scott
