If you can see it on the layout, then it will print.
The only other option I can think of other than what Erwin suggested, is to have two layouts.
One that shows the text you want just for viewing, and one that hides it - this one you will publish.
Of course this means the text must be in a layer that can be turned on/off for the saved views that will be used on the layouts.
