Design forum
The Graphisoft Learn Portal
Mjules
The Graphisoft Learning Portal is designed to help users learn or master Archicad. I think this portal is very interesting for us, as users and needs to be better marketed everywhere around the globe. This can help both existing and new users.
Please take a look at the following hyperlink for example if you want to have a better idea about the Archicad capabilities in terms of energy efficiency.  You need to be an Archicad subscriber. If you're not a subscriber yet, contact your local partner that you can find on the Graphisoft website.
Certified Archicad Energy Analysis Trainers - https://learn.Graphisoft.com/group/show/13786
Martin Luther Jules
AC 10-26 (Full)
Asus | 64 GB RAM | Windows 11
Martin - AFAIK, that link is for a private forum for TRAINERS, but is not an actual course.
Courses (32 as I write) are available from the home page left menubar > Catalog.  Many are free to SSA members. Simply signing in with your GSID associated with your SSA will provide access... although some courses and materials require entering a code (given on the course page if for SSA members) or possibly a fee, with SSA getting a discount.
There are no courses related to energy analysis as of today.
One of the forum moderators   •   AC 26 USA and earlier   •   macOS 12.6.1, iMac Pro 10-Core, Radeon Pro Vega 64
6 REPLIES 6
Andrii Levko
It's good, but an access code is required. How can a simple user with SSA get this code?
Andrii
AC 8.1 - 25 INT/POL 5010
@Andrii Levko I sent an email to Graphisoft regarding this matter since we need this kind of trainings to better understand the software in terms of energy modeling for example.
Martin Luther Jules
AC 10-26 (Full)
@Mjules Thank you for information. So everyone who needs this training should send a mail to Graphisoft ? I think this is too complicated. Why not just let people buy the course or use the FORWARD/SSA coupon code for free access if you are a FORWARD/SSA client! Or maybe it's some kind of secret partner-only course.
Andrii
This is a good point, @Andrii Levko
Martin Luther Jules
AC 10-26 (Full)
Karl,
Thanks for the clarification. I'll be waiting for this course!
Martin Luther Jules
AC 10-26 (Full)
Didn't find the answer? Start a new discussion
