The railing is shown as a whole glass material
reisentt
Why, in my file, rails are all displayed whole as glass materials, but in other documents, railing can be displayed normally?!!?
Reiset Yang
Architecture Student
AC21 XPS15 15.6" 2.80GHz Solo-core i7-7700HQ | 16 gb ram
10 REPLIES 10
reisentt
But when I copied the handrails into another file, I could show them correctly.
Reiset Yang
alemanda
Check the MVO settings. Maybe the railings are set to schematic anche there’s a graphic override among those settings to change the materials to a single material which is glass by default
AC 19 and AC21 latest hotfix
Win 10 Pro 64bit
Double XEON 14 CORES (tot 28 physical cores)
32GB RAM - SSD 256GB - Nvidia Quadro K620
Display DELL 25'' 2560x1440
www.almadw.it
reisentt
Would you like to tell me where is MVO settings?
I'm not very proficient at this.
Reiset Yang
David Maudlin
reisentt:
In the Standard Work Environment: Document > Model View > Model View Options... > Stair and Railing Options > Railing Detail Level in 3D and Section:.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
reisentt
Thank you for this patient guidance!
I have checked the settings according to your method, but the railing is still the same. I think this may be a BUG in the software.
Reiset Yang
David Maudlin
reisentt:
It could be a Graphic Override (GO) that is changing the Railing's Surfaces to glass. Look at Document > Graphic Overrides.
Thanks for adding the signature.
David
reisentt
I have canceled Graphic override in this file. But it's still not back to normal
Thank you for your help. I think this should be an unknown BUG in the document itself.
Reiset Yang
nagyb
I have the same problem right now in Archicad 24. Did you found a solution?
runxel
Legend
Have you checked the MVO? This is mostly the main issue.
