Tracking Down Missing Objects
Dave Jochum
I always have a dozen or so "Missing Objects" when loading my libraries (Bolt 2, Scotia, Interior Reveal 2, etc.) They are objects I've never used. Is there a way to track down which library they are from and discover why they are "missing"?
Dave Jochum
J o c h u m A R C H I T E C T S http://www.jochumarchitects.com
MBP 16" (M1 Max) 64 GB•OS 13.5.2•AC 27 Silicon (latest build)
4 REPLIES 4
I'm not sure but they sound like MSA parts.
David Larrew
You can use the "Find & Select" Tool to track-down each missing object (by name) on each Story or in the 3D window (if they are 3D objects).
If they are only showing up in the Library Manager - just "Remove" the individual objects from the Loaded Libraries.
David Larrew, AIA, GDLA, GSRC
Architectural Technology Specialist
a r c h i S O L U T I O N S
WIN7-10/ OSX 10.15.7
AC 5.1-25 USA
Dave Jochum
I guess my confusion stems from a part "missing" that I've never placed in the project. "Find and Select" won't return anything since the objects aren't present. I will try "removing" them, which will probably work, but what is actually going on if I am removing something that doesn't exist? Why is the Library Manager noting these objects as missing?
Dave Jochum
David Larrew
If the project file was started without the use of a template file (New - Use Latest Settings) then you will retain any residual "missing" Objects from the last file worked on. This might be the case with this file.
AC 5.1-25 USA
Learn and get certified!
