Transfer multi story building into new Archicad file
GREJX
Hi all. I have been working on a multi level building and now want to copy into a new file.
I use the thick marquee to copy all stories, however only 1 story is transferred?
Appreciate any help!
Thanks
GREJX
....all good, just created a mod file and worked.
5 REPLIES 5
There is an option under the file menu to ‘Merge’. You can import an entire model or all of the layouts. I don’t have access to Archicad at the moment to say exactly where it is but it’s definitely in the File menu.
Lee Hankins
ArchiCAD 4.5 - Archicad 27UKI Apple Silicon 27.1.1
macOS Sonoma (14.2)
GREJX
Cool. I assume you know that you won’t be able to modify the model without opening it in the original file.
Lee Hankins
macOS Sonoma (14.2)
GREJX
I haven't hot linked it so its fully editable. I simply merged the mod file.
Or, if you did hotlink it, you can break the hotlink.
