Design forum
Transparent colors
Samuel EBULU-AMOUDA
Are transparent colors available in Archicad? Can they be created? How?
runxel
Mentor
Depends on your definition of "color".
You can create translucent and transparetn materials.
Fills can have pen number zero in the background, which makes them translucent.
Pens however are always solid, and so are all lines.
AC 24 [ger] | Win 10 | Developer of the GDL plugin for Sublime Text |
runxel
Mentor
ZuMedeiros
You can create transparent surfaces, transparent fills... What do you need?
Steve Jepson
ArchiCAD 25 3002 USA - Windows 10 Pro 64x - Dell 7720 64 GB 2400MHz ECC - Xeon E3 1535M v6 4.20GHz - (2) 1TB M.2 PCIe Class 50 SSD's - 17.3" UHD IPS (3840x2160) - Nvidia Quadro P5000 16GB GDDR5
Maxwell Studio/Render 5.2.1.49 Multilight 2.1.0.1
