Transparent colors
Samuel EBULU-AMOUDA
Are transparent colors available in Archicad? Can they be created? How?
runxel
Legend
Depends on your definition of "color".
You can create translucent and transparetn materials.
Fills can have pen number zero in the background, which makes them translucent.
Pens however are always solid, and so are all lines.
Lucas Becker | AC 27 on Mac | Author of Runxel's Archicad Wiki | Editor at SelfGDL | Developer of the GDL plugin for Sublime Text |
«Furthermore, I consider that Carth... yearly releases must be destroyed»
runxel
Legend
ZuMedeiros
You can create transparent surfaces, transparent fills... What do you need?
