UK Essential Library 23
fuzzytnth3
Does anyone know if the UK Essential Library 23 has stopped being supported?
tia
AC versions 3.41 to 25 (UKI Full 5005).
Using AC25 5005 UKI FULL
Mac OSX 10.15.7 (19G2021) Mac Pro-2013 32gbRam AMD FirePro D500 3072 MB graphics
Generally we do not update objects to new GDL script version (mind you that GDL script version is not the same as Archicad release number) if it is not completely necessary, e.g. in case of compatibility issues. Anyway we release a new version of UK Essential Library with every new version of Archicad. You can download those from UAS Downloads, refer to the Special Libraries section (access requires GSID with an active UAS or Forward subscription): https://graphisoft.com/uk/downloads/uas
::rk
4 REPLIES 4
Rob
What do you mean? Have you found bugs or you can't download it?
::rk
fuzzytnth3
It was in light of this article
Link
"Support" as in keeping the Objects up to date with the current version of Archicad
::rk
fuzzytnth3
Ah I didn't see that page when looking in UAS Downloads. Ok thanks for that.
