Design forum
Unable to change railing materials
Manish
Hello everyone,
Need help!!
Archicad 23:
I am unable to change my railing materials. When I am creating a new railing ti shows a single material, which is not editable. I tried a lot but had no success. Even if I am importing or copying a railing from another project, that also has one single material.
Photograph attached.
Regards, Manish
SwedishChef
Check your MVO settings and make sure you don't have simplified with an Override Material on.
DELL Precision 5560
i7-11850, 32 GB, RTX A2000
AC12 - future
4 REPLIES 4
vistasp
Do you have a graphic override active?
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
| AC 9-25 INT | Win10 | Ryzen 2600 | 16 GB | GTX 1150Ti |
Thanks Vistasp, found the solution.
Problem was in MVO setting.
Regards
SwedishChef
DELL Precision 5560
AC12 - future
Thanks, Yes there was there problem.
Regards
Didn't find the answer? Start a new discussion
Labels
