Design forum
Undo roof trim in Archicad 19
johanes
Does anyone know where is the command "Undo roof trim" in Archicad 19? I knew that is found in the properties of the object are cut. In Archicad can not find 19 this command ...
2 ACCEPTED SOLUTIONS
Dontknow
Select the wall, richt click and select Connect' and 'Clear All Connections'.
Architectural construction designer, draftsman, modeller
ArchiCAD 24.
James B
You may be referring to the Crop command.
Design > Roof Extras > Undo All Crops
Technical Product Manager, Graphisoft
Dontknow
ArchiCAD 24.
James B
Didn't find the answer? Start a new discussion
Labels
