Browse
Graphisoft Community
All
This category
This board
Articles
Users
Products
Design
Design articles
Design forum
Document & Visualize
Document articles
Visualize articles
Document & Visualize forum
Collaborate
Teamwork articles
Data Exchange articles
Project Management articles
Collaborate forum
Setup & License
Let's get started!
Setup & License articles
Setup & License forum
Get Together
What's new?
Wishes forum
Developer forum
Graphisoft User Group
Graphisoft Insights
Challenges
Parametric Object Factory
My Graphi Story
One Override to Rule Them All
Snow Globe Challenge
Português (Brasil)
日本
International
search
Help
All
This category
This board
Articles
Users
Products
Design forum
Graphisoft Community (INT)
Design
Design forum
Re: Undo roof trim in Archicad 19
Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Pin this post for me
Bookmark
Subscribe to Topic
Mute
Printer Friendly Page
Go to solution
johanes
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report Inappropriate Content
2015-09-16
08:45 AM
Does anyone know where is the command "Undo roof trim" in Archicad 19? I knew that is found in the properties of the object are cut. In Archicad can not find 19 this command ...
Solved!
Go to Solution.
Labels:
Labels:
Design
All forum topics
Previous Topic
Next Topic
2 ACCEPTED SOLUTIONS
2
Go to solution
Dontknow
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
2015-09-16
01:48 PM
Select the wall, richt click and select Connect' and 'Clear All Connections'.
Architectural construction designer, draftsman, modeller
ArchiCAD 25.
Go to solution
James B
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
2015-09-16
02:53 PM
You may be referring to the Crop command.
Design > Roof Extras > Undo All Crops
James Badcock
GRAPHISOFT Product Manager
Post Reply
Didn't find the answer? Start a new discussion
Create new topic
Related articles
Is it possible to create a glass dome with curtain wall like in Revit
in
Design forum
Convert lines/circles to roof
in
Design forum
Two walls trimmed by one roof, from both sides.
in
Design forum
Trimmed wall and roof - floor plan
in
Design forum
Angled beam object does not display correctly in floor plan
in
Design forum
Labels
2D Elements
2
Add-ons
21
Annotation
1
Attributes
4
Beams
20
BIMx
2
Classification & Properties
1
Columns
11
Complex Profiles
42
Composites
29
Curtain Walls
27
Design
17,322
Doors & Windows
108
Drawings
5
EcoDesigner
174
Edu
473
GDL
6,949
Goodies
3
Graphic Overrides
1
Graphisoft Insights
1
Grasshopper
218
Intersection
34
Layouts
2
Library
6,895
Mesh
21
Morphs
14
Objects
87
Openings
20
Other
186
PARAM-O
11
Performance
2
Presentation
1
Project Management
1
Project Presentation
2
Publishing
1
Rendering
1
Rhino & Grasshopper
25
Roofs
1
Roofs & Shells
33
Skylights
6
Slabs
25
Solid Element Operations
23
Stairs & Railings
46
Student
478
Surfaces
2
Sustainable architecture
174
Teamwork
1
Templates
3
Tips & Tricks
232
Troubleshooting
95
UI
1
Views
2
Walls
75
Latest solutions
Hatch pattern shows through the doors and windows ...
Design forum
How to create a non-continuous layer in the compos...
Design forum
How to cut out pieces of a roof or slab
Design forum
How to group objects so that selecting one selects...
Design forum
Ecodesigner Beta Link
Design forum
View all
Most liked posts
Subject
Likes
Pritzker and Archicad
5
Re: Dark Mode Bug
4
Re: Dark Mode Bug
3
Re: Dark Mode Bug
3
Hotlinks & Classifications
3
View all
Create new topic
