2018-02-2111:20 AM - last edited on 2023-05-2412:27 PM by Rubia Torres
When I insert a door or window into a wall the new object is accompanied by text saying "Custom" and then showing the door/window dimensions. I can't find any settings in parameters or elsewhere related to this text. How do I get rid of this text?
Thanks.
It is the Door or Window Marker. In the Door or Window Settings it is in the Dimension Marker panel, where it can be set to "No Marker". If you want the Markers for some Views, the use Model View Options > Construction Element Options > Door Options / Window Options > "with Markers" to control their visibility.
David
David Maudlin / Architect www.davidmaudlin.com Digital Architecture AC27 USA • iMac 27" 4.0GHz Quad-core i7 OSX11 | 24 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
David
