Design forum
Up to date script but missing parameter
JGoode
Hello,
I created an object and it needed to be edited. I added a parameter and wrote some code in the master / 2d etc. When a colleague tried to use it, it came up as an error. I checked on my pc and it was working correctly but when I opened the object in his project, all of the script was definitely up to date but the parameter was nowhere to be found. I asked my colleague to reload their libraries and it worked correctly. I was wondering if this has happened to anybody else or whether it was just a strange bug?
Thanks!
ArchiCAD 23
Windows 10
2 REPLIES 2
Erwin Edel
ArchiCAD creates a cached version of your library after loading it. If you change objects, you need to reload for them to take effect.
www.leloup.nl
ArchiCAD 9-24 NED FULL
Windows 10 Pro
Adobe Design Premium CS5
JGoode
The library was reloaded the first time as I checked the gdl editor and all of the script was how it should be but the parameter was missing until the library was reloaded a second time. Strange!
ArchiCAD 23
Windows 10
Didn't find the answer? Start a new discussion
