Parametric design
About Rhino & Grasshopper and PARAM-O.
Urgent: ArchiCAD 23 update 5005
My company is doing an update for ArchiCAD 23: 5005 and I wonder if I could continue working with the live connection? From previous version I remembered that I got problem if the live connection version doesn't have the same update as ArchiCAD. That's pretty urgent so I would appreciate an answer from developpers
Right now the Grasshopper-Archicad 23 Live Connection is Compatible with Archicad build 4006 not with 5005.
Thanks in advance,
Best regards,
Frank
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
HI Frank,
Thank you for the question!
The Grasshopper - Archicad Live Connection made for AC23, although stated for 4006, should work perfectly fine with newer build of Archicad 23. I am using it with build 5005 without any compatibility issue.
In short, the latest version of the addon should be compatible with Archicad 23 5005.
Please let me know if you have any further questions. Thank you very much!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
Hi Minh,
Thanks for your quick answer
Frank
