Design forum
User globals loosing values from floor to elevation windows
With ArchiCAD9.0 we used to set some user’s global variables (GLOB_USER_1 to GLOB_USER_20) from an element’s master script (we call it as DataBlock) and we use them in other elements master script. We never had any problem in elevation windows or in 3d window.
Now we are using same library in ArchiCAD12.0, the other elements loosing GLOB_USER values in elevation windows or in 3d window.
Example:
DataBlock Master Script:
if published then
if drawing_type_a then
glob_user_2 = 1
else
glob_user_2 = 2
endif
else
glob_user_2 = 99
endif
Other elements Master Script:
if glob_user_2 <> 99 then
Published = true
else
Published = false
endif
I am getting glob_user_2 = 2 in the floor plan. But, I am getting glob_user_2 = 0 in elevation windows or in 3d window. Other than glob_user_2 all user’s globals values I am getting 0 or empty string.
Is there any problem with ArchiCAD12.0 or is there any other way I can use all my user’s globals in any window.
6 REPLIES 6
Didn't find the answer? Start a new discussion
Labels
