SOLVED!
Using custom railing macro with Stairmaker?
Hi, everyone
I had to modify some structural dimensions in one of the railing macros that come with ArchiCAD (Rail Posts with Balusters). Now I have a standalone railing object and a modified macro loaded with my custom library.
Is there a way to include that custom macro on the list that appears for railing choices when you edit the ArchiCAD stair object so it could be auto-generated with the stair?
Thank you!
1 ACCEPTED SOLUTION
Solution
Erwin Edel
Stairmaker does not use the railing objects from the library, but rather it's own scripted railings.
If you use ArchiCAD21 and onwards, there is a new stair tool and a new railing tool that solves this problem.
I never use stairmaker railings myself in ArchiCAD20 and before, you can use most of the railing objects from the library on a slope and curved etc, so with a few adjustments, you can place them with stairs.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
1 REPLY 1
Solution
Erwin Edel
www.leloup.nl
Windows 10 Pro
Learn and get certified!
