VARTYPE line error
JGoode
I keep getting an error on the "IF n > 0 AND VARTYPE (var) = 2 THEN" line
I don't know what's causing it or how to fix it.
DIM sarray[]
! file in the library, containing parameter data
filename = "ProjectNotes.txt"
ch1 = OPEN ("text", filename, "MODE=RO, LIBRARY")
i = 1
j = 1
sarray[1] = ""
! collect all strings
DO
    n = INPUT (ch1, i, 1, var)
        sarray = var
        j = j + 1
    ENDIF
    i = i + 1
WHILE n > 0
CLOSE ch1
! parameter popup with strings read from the file
VALUES "RefNote" sarray
ArchiCAD 23
Windows 10
Pertti Paasky
Works with me. Check parameter "RefNote" in the parameters' tab, it's type should be text.
-The text file must be in the loaded library.It must not be opened in any other application at the same time.
- AC-24 FIN - WIN 10 - HP Zbook -
“A winner is just a loser who tried one more time.”
George M. Moore, Jr.
Create var parameter, or declare var = 0 in the script. And there will be no mistakes.
Gergely Feher
If the input is not successful, then vartype will be uninitialized. So you should split it to two conditions:
if n > 0 then
    if vartype (var) = 2 then
_________________
Gergely Fehér
Team Leader, Library Team
GRAPHISOFT SE
