2004-11-16 05:37 AM
2004-11-17 02:39 AM
2004-11-17 07:16 AM
2004-11-17 05:11 PM
2004-11-18 12:36 AM
2004-11-22 06:01 PM
2004-11-22 07:20 PM
Where have you found the possible values 43, 44 and 46 of GLOB_CONTEXT?they have been mentioned in the AC help under GDL Reference manual/Global Variables/General Environment Info. I am still using AC8.1 so it could get changed with AC9.0 help...
2004-11-22 08:00 PM
1-library part editor, 2-floor plan, 3-3D view, 4-section/elevation, 5-settings dialog, 6-list, 7 - detail drawing, 22 - feedback mode from the floor plan, 23 - feedback mode from aWhat does "generating as an operator" mean? That the object is an operator in a solid element op?
3Dview, 24 - feedback mode from a section/elevation, 43 - generating as an operator from a 3D view, 44 - generating as an operator from a section/elevation, 46 - generating as an
operator from a list
2004-11-25 09:21 PM
2005-04-04 07:07 PM
Rob wrote:I've tried it but didn't work as discribed!
When you have a library part with moveable hotspot (diamond shape) on plan and you will move it you will get the value of 22 (feedback form plan) in GLOB_CONTEXT global variable. It is a very same thingy for 3D window. So, basically you can respond to hospots 'moving' action within your lib part script.
