View to Layout issue
Hi!
Help me please with one issue. Working with this interior:
Looking at View from the top you can see correct picture:
But if you put this View to Layout, it will be incorrect:
Why this is happens? Suppose it is something with Floor Plan Cut Plane (but I changed it to the one height everywhere). How can I transfer the View to Layout without losing it's settings?
1 REPLY 1
Ok, guys, I found the answer after two evenings spent on the issue.
Actually, I think this is a bug of Archicad. It seems that View doesn't correct save Cut Plane height when you changes it. In order to correct this you must: [list=]
  • 1. Go to Floor Plan Cut Plane and change Cut Plane height to appropriate;
  • [list=]
  • 2. Go to the View settings:
  • [list=]
  • 3. Click Get Current Window's Settings
  • After that click OK and close View Settngs and go to the Layout with the View. The View will be corrected with correct Cut Plane height.
    I want to mention that nothing will be changed in terms of combination in GENERAL settings group (of the View Settings). Only zooming option will be changed to Current Zoom.
    Learn and get certified!
