Design forum
W Sliding3 21 Window
mukster
Using Archicad 21 on a Mac platform. Putting in a 3 panel sliding window with a center picture. I can find no way to adjust the width of the panels. We need to make the center panel larger than the 2 side panels.
3 REPLIES 3
Do you have the '3-Sash Sliding Window 21'?
This is available in the AUS library - not sure about other languages.
If so you can set the panel configuration to custom.
Versions 6.5 to 25
Dell Precision 3510 - i7 6820HQ @ 2.70GHz, 16GB RAM, AMD FirePro W5130M, Windows 10
Lingwisyer
Legend
Which edition of AC are you using? If I recall correctly, the US edition uses different windows than that shown in Barry's post as he pointed out. I think the INT edition has the same windows and AUS so you might be able to use that if need be.
Ling.
Win10 | R5 2600 | 16GB | GTX1660
mukster
Using AC23 now in the US. This option is not available on my version. I'll have to look this up
Didn't find the answer? Start a new discussion
