W double hung 21
RandyC
Both of the windows (W double hung 21) and (W single hung 21) have Flip greyed out -- Neither window will put the dimensions and label on the correct side
( the side with the sun when placing ) -- They will not work properly with
(Basic widow door dimension marker ) and (W marker 21)
They work however with (builder dimension 21)
has anyone else noticed this ?
ArchiCAD 4.5 --- 27 , Win 10 , dual monitors, 64 gb ram,Nvidia GeforceRTX 2080 TI, I-9
1 REPLY 1
Daniel Kovacs
Graphisoft Alumni
Graphisoft Alumni
The Markers are always placed on the inside by default (so if you defined the outside with the little sun to be on the right side of the screen, the marker will be placed on the left). In the basic door/window markers there are no settings to change this (they are this basic), but all the other markers have a "Flip" or "Opposite Side" option in their settings to change this.
As for the Flip being greyed out, for certain doors/windows flipping would not make sense in the other direction (like garage doors usually open inwards).
In this case, you have already marked the outside face with the little sun symbol, so we know where the outside is, and the lower (moving) part of a single hung window is usually the one inside. Double hung windows are just a spin on this, so the lower part is the inner part in those as well.
If you don't think these specific windows should work like this, please add it as a wish type post on this site to see if it is a popular wish, or talk to your local support/reseller to change this in future versions.
Regards,
Daniel Alexander Kovacs
GRAPHISOFT
Learn and get certified!
