poco2013 wrote:
Attached is unlisted video describing the problem.
Any ideas would be appreciated. -- did reload goodies & Archicad - no luck
www.youtube.com/watch?v=gkIlyHmaC-Ehttp://
Interesting problem.
Just to explain the video a bit, the wall accessory is working - but not for walls in particular areas.
Drag the wall in or out of the specific area and the wall accessory appears/disappears.
This makes me think there is nothing wrong with the accessory tool.
I am inclined to think that there is something in that position that is trimming the wall (the plan view may not be affected) so that the accessory object becomes invalid.
The object gets the geometry from the wall it is associated to so if something is happening to the wall that it doesn't like that would explain the problem.
It is hard to say what might be happening without seeing the file but this is what I would try.
What does the actual wall look like in 3D? (the accessories can be applied in 3D as well).
Drag a copy of the wall that is working to the area that is not working.
Select both of the walls and look at them in 3D.
Do they look identical or is one of them being trimmed by some hidden element?
In the layer settings change the intersection priority number for the layer the wall is on so it is different to all other layers (or set it to zero).
Now it will not automatically trim with other elements.
Does the accessory work now?
If this is not the issue then I am at a bit of a loss for other ideas without playing with the file.
