SOLVED!
Wall End tool and Profile Based Walls !
Ghassan Kanaan
Hello,
I found that the Wall End Tool doesn't work for Profile Based Walls.
Is there a way to overcome that with other methods ?
Thank you
1 ACCEPTED SOLUTION
Solution
Hello Ghassan Kanaan,
If you appreciate Profile Based Walls why don't you use Profile Column by the same way to modelise wall end ?
Christophe - FRANCE
Archicad Designer and Teacher
Archicad 15 to 27 FRA FULL
OS 11.6 Big Sur - MacBook Pro 2017 - 16Go RAM
"Quality is never an accident ; it's always the result of an intelligent effort" John Ruskin
2 REPLIES 2
Solution
Christophe - FRANCE
Ghassan Kanaan
Thank you Christophe Fourtineau, I will try this ( Merci )
