Wall Skins display issue after turning in for door/window.
Rajesh Patil
For Door/ Window " Inner and Outer Plaster Skins" are turned-in correctly on floor plan, but why they didn't get displayed in the same manner in 3D Cut View? Any settings to adjust?2021-09-25 (8).png
Rajesh Patil
AC 09-27 | INT | WIN11 64
Dell Inspiron 7591, Core i9, 9880H 2.30GHz, 16.0GB, NVidia GeForce GTX1650, 4.0GB, SSD Internal 500GB, Dell SSD External 250GB
Wall Closure display is limited to 2D views.
What you can get in 3D views by checking 'Show in 3D' is an extension of the wall into the opening corresponding to the plaster thickness. But you cant get a modelled turn of the skin.
True, but that leads to incorrect presentation in 3D documents. Wish this problem should get solved in coming version.
Rajesh Patil
