Ignacio wrote:
the add-on considers the niche as a full opening, so that interior base and crown get interrupted in correspondence with that exterior niche.
That might be because it is a full opening, it just fills in the bit behind the niche.
You are using version 24 - have you tried using the opening tool with limited depth rather than the niche window?
I have not tried this, so I can't say if it will work or not, but it's worth a try.
