Design forum
Wall building
In ADT and especially revit there is a lovely function to custom design the type of wall im building. I can build up a wall in layers saying what it is, how thick it is, building from the inside to the final render on the outside. e.g. block, insil, cav, masonary block, render. I know there are a few preset walls. How do i build up my walls so the detail shows up nicely in the plan and section view?
the type of wall im using is stone clad. (hopefully an easy one to answer)
thanks guys!
Bry
2 REPLIES 2
Bry; Go to the options menu/composites. Find a wall that is close to what you want and duplicate it. Now change away. Rename it Bry's stone clad wall or something relevent. So that all walls clean up properly, the core of the wall should have the same fille, ie stud cavity. Hope that helps.
thanks, thats better!
Didn't find the answer? Start a new discussion
