Wall connections
Hello forum,
I have a completely "noobish" question,but its driving me mad.
So, I have this wall (1) and I want to create a second wall (2) in front of it,
they both have the same height , actually they are connected to the top floor.
But for the life of me, I cannot have the black border line gone,so they appear as one.
Any suggestions?
Cheers
11 REPLIES 11
Eduardo Rolon
Use the column tool to define the new thickness.
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
Rod Jurich
............ or you can split the wall and use a second wall as a pier.
The col tool doesn't always play nice Ensure your ref line connects.
Rod Jurich
AC4.55 - AC14 INT (4204) |  | OBJECTiVE |
Thank you both for the answers!
I already knew I could use the column, I should have clarified that I want to see if I can get the wanted result with using only the wall tool.
Rod could you please explain a bit more what you mean?
Cheers
Try using a perpendicular wall changing the thickness.
Hey Ilder, I already tried that but with no luck.
troakie45
Patch!?
Anestis, don't tell me so
I've tried it and it works well, If your wall is "base" profile it works, if your wall is "composite" profile you need to create another composite profile with the right thickness, and it works (if you don't mess up intersection priority..) please try again.
Hehe, I know its weird. The weirdest thing about it, is that in the same project, I have the same connection between walls on another side,but it works!
By now I found a solution, I have used the column as previously suggested and now I am mainly trying to figure it out just for training reasons.
Rod Jurich
Cheers
I use 2 wall types one 110mm and the other 230mm
Same material and have reference lines meeting.
I use this particularly with face brick walls, otherwise
use the col tool.
In 3D select your walls and set material origin to start
at the same starting point.
Rod Jurich
