Wall skins at 3d openings in 17
David Collins
Is it true that the new wall skins ArchiCAD 17 are not yet smart enough to turn in at window openings in 3d? Or is there a setting someplace that I'm missing?
David Collins
Win10 64bit Intel i7 6700 3.40 Ghz, 32 Gb RAM, GeForce RTX 3070
AC 27.0 (4001 INT FULL)
Shivang Rajvir
The Plaster skin does not turn in 3D by default, this means you can do some 2D touch ups or can add special details.
Have a look at
http://archicad-talk.graphisoft.com/viewtopic.php?p=216280&highlight=plaster#216280
ARCHICAD Lover
http://www.dimensionplus.in
Core i7 3.4 GHz, AC 9 to 22
MacBook Air Core i3 1.6 GHz - 8 Gb RAM
David Collins
Yes, this was always an issue, but Hope Springs Eternal.
The real problem is that the window head in section is still going to need a patch or something.
I suppose you could insert a complex profile lintel beam with the plaster return, which would get the section detail closer to how it needs to look, but keeping the windows and their lintel beams coordinated throughout the project is going to be a pain. I suspect a 2d patch slapped on at the end is still going to be a simpler and faster solution for now.
David Collins
