White fills show up grey
I'm not sure what exactly has happened here. I'm pretty sure I didn't do anything, but I must have done something.changed some setting by mistake, because all of my white pens show up grey. I'm using Archicad 12, Student Education version on Windows XP. I've attached a screen shot. As you can see my pen set says the fill is white, but like the brick workabove, the highlighted concrete fill is showing up with a grey background. Anyone know whats happened here?
owen
and the correct answer is:
Automatic Pen Color Visibility Adjustment
go to Options > Work Environment > More Options and make sure it is unchecked (second from the top). This setting basically temporarily overrides any pens that would not be visible due to the screen background color (so white on white or black on black)
cheers,
Owen Sharp
Design Technology Manager
fjmt | francis-jones morehen thorp
iMac 27" i7 2.93Ghz | 32GB RAM | OS 10.10 | Since AC5
11 REPLIES 11
owen
I was going to say check you haven't accidentally turned on Uniform Pen overrides in the Section tool but just noticed there are some green pens at the edge of the screenshot so that can't be it (assuming this is a pure model cut, no manual lines)
cheers,
Owen Sharp
owen
cheers,
Owen Sharp
Perfect!
Thank you Owen..
I have no Idea how that got checked, but it was..
Problem solved.
Thanks so much for your help.
That was DRIVING ME NUTS for two days!!! Thanks so much for the info. I know the post is old, but still helped me out.
You're my savior! I was about to hit the screen with a hammer. Cheers!
(Works for AC 21 too)
I find it best to not use a pure white background (or black).
I set mine to a pale green (like the old manual drawing boards for those that remember them).
That way I can see all pen colours including white.
Depending on the pen colours you use you can to adjust the background colour to suit what works for you.
Cosmin Ghioanca
Give this guy a beer!
Archicad 6-6.5-9-10-11-13-15-16-18-20-21-22-23
64-bit OS Windows 10 Pro
AMD Phenom II X4 965 3.40 GHz CPU
AMD Radeon HD 5670 GPU
Samsung SSD 860 EVO 512(500)GB SATA
WDC WD10EALX-009BA0 1TB(931)GB SATA
WD MyPassport 259F 1TB(931)GB USB3
thankkkkkkkk you so much I was also about to quit architecture...
Rene Pahlavan
Update for anyone else using this thread:
On my AC 25 US this option is under "Work Environment" --> "On Screen Options" (fourth from the top). Not found in "More Options".
AC27 (Apple Silicon)
macOS Sonoma 14.1.2.
MBP M3 Max (16-inch 2023)
