Mats wrote:
EcoDesigner uses VIP-Energys calculation kernel and for VIP-Energy we know that normally the result should be within 3%.
But do we have any idea what error margins we can expect from EcoDesigner. ... for Swedish condition the typical result for this kind of very fast calculation were within 10%.
EcoDesigner should be accurate enough to give a clear picture about how the building will perform. ... Export the data to VIP-Energy and you also will have very accurate results for final review.
Hi Mats,
Thanks for joining this discussion! I am confused about the excerpts above. I'm encouraged that you think the error factor is so much lower than the link on the StruSoft web site. (I do not understand why that link is there, if those numbers are not applicable.)
If EcoDesigner uses the same calculation kernel as VIP-Energy, then how is it that VIP-Energy is so much more accurate? ... and what is it that VIP-Energy itself would do beyond EcoDesigner that a customer would want to export the ED data to VIP-Energy? How much other information must be provided to VIP-Energy to get that more accurate result?
In particular, even an error rate of 10% might be considered big, since it implies that if I run ED and get a 10% improvement with one variant (changing windows on one side of the building to better ones), I really will not know if I am seeing a real improvement or just the error rate. (Equivalently, that error rate might say that I would see an increase in energy of up to 10% even if I put in better windows ... which would not exactly guide the decision-making process.)
Thanks!
One of the forum moderators
AC 27 USA and earlier • macOS Ventura 13.6.6, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
