Why I can't trim and split chained wall ?
Hello !
Strange but I can't find much info about trimming a chained wall on internet , nor can find in docs. I mean this
Simple wall is trimming without problems , but this wall won't trim, in fact I'm interested in trimming and also if it is possible to explode chained wall in points/corners. Any ideas ?
Dontknow
When you want to trim a chained wall, first activate the 'Suspend Groups' button.
Architectural construction designer, draftsman, modeller
ArchiCAD 25.
1 REPLY 1
Dontknow
ArchiCAD 25.
