Why can't the beam be blocked by the door in section?
LeeJaeYoung
this is section
Why can't the beam be blocked by the door?
I copied the one on the right, but I can't see it
this is plan
this is  beam
this is section
AC27 on window 11
3 ACCEPTED SOLUTIONS
Andrii
AC 8.1 - 27 INT/POL 3001
Win11 | Ryzen 5600 | 16 GB | GTX 1650
Maybe is better to assign a beam (with priority as you had before) to another layer and give this layer a higher priority, for example 2. Because the priority of layers is probably higher than intesection priority, But I am not sure if there will be a good connection between the insulation beam and the insulation wall, then you probably have to give all the insulation element to this layer.
Andrii
But you just have to remember to do the update for the layer combination !!!
Andrii
16 REPLIES 16
Andrii Levko
Building materials priority.  You have to give your beam the same or higher priority for building material than the wall.
Andrii
this is section
Then, how can I model the cross section like this?
AC27 on window 11
In main menu choose Options/Element Attributes/Building materials,  you can find there "Intersection priority" and give for building material of beam  higher priority then building material of the wall.
Andrii
Andrii
Thank you so much ^^
Insulation does not need to be combined
The plasterboard and other materials above must be combined.
AC27 on window 11
I just give you the answer, you can just check if it works or not.
And to combine or not, you have to decide for yourself.
But you can always duplicate building material using it for special cases such as you have with this beam.
Andrii
Because the beam is invisible by intersection priority.
Andrii
Andrii Levko
As an option, you can assign a beam to another layer and give this layer a higher priority, for example 2. Because the priority of layers is probably higher than intesection priority
Andrii
thank you so much
If it were you, how would you make it?
I am a beginner.
AC27 on window 11
