2022-09-20 12:56 AM
Q4. Why is there a stair finish in CORE ONLY?
Solved! Go to Solution.
2022-09-20 10:23 PM
1. You made me switch from End Riser to End Tread.
2. So I have to use SOE.
3. And adding an if statement seems to be a better solution than adding an if statement to the profile.
2022-09-20 10:42 PM
Your answer raised a question about 2D.
If possible, we would appreciate it if you could check the questions below.
